5. FreeRTOS
5.1 FreeRTOS Resources
5.2 FreeRTOS Tasks
我们编写如下代码:
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include "freertos/FreeRTOS.h"
#include "freertos/task.h"
void task1()
while (true)
printf("reading temperature\n");
vTaskDelay(1000 / portTICK_PERIOD_MS);
void task2()
while (true)
printf("reading humidity\n");
vTaskDelay(2000 / portTICK_PERIOD_MS);
void app_main(void)
task1();
task2();
输出结果为:
可见一直在循环 task1,那么我们要让两个任务交错运行要怎么办呢?
我们需要用到这个函数 xTaskCreate
(x means this function returns something)
参数解释:Task地址,Task别名,最大使用的空间大小,参数,优先级,调用task的指针
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
void task1()
while (true)
void task2()
while (true)
void app_main(void)
xTaskCreate(&task1, "temperature reading", 2048, NULL, 2,NULL);
xTaskCreate(&task2, "humidity reading", 2048, NULL, 2,NULL);
我们可以传各种参数,例如:
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
void task1(void * params)
while (true)
printf("reading temperature from %s\n", (char *) params);
void task2(void * params)
while (true)
printf("reading humidity from %s\n", (char *) params);
void app_main(void)
xTaskCreate(&task1, "temperature reading", 2048, "task 1", 2, NULL);
xTaskCreate(&task2, "humidity reading", 2048, "task 2", 2, NULL);
5.3 Using the Second Core
可以发现 Esp32 有两个核心
我们可以使用 xTaskCreatePinnedToCore
函数,这个函数前面的参数和 xTaskCreate
一样,最后一个参数为绑定的核心,默认为核心0,可以手动选择核心0或核心1
5.4 FreeRTOS Tasks Decision Tree
FreeRTOS interaction between 2 or more tasks
I want to commmunicate directly to another task. I care about counting or sending simple data → Task Notification
| No
someone needs to block or unblock a task. I Don’t care who → Semaphore
| No
Only the task that blocks a another task can unblock it → Mutex
| No
I need to pass data from one task to another → Queue
| No
multiple things need to happen before I unblock a task → Event group
5.5 Task Notifications 1
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
static TaskHandle_t receiverHandler = NULL;
void sender(void * params)
while (true)
xTaskNotifyGive(receiverHandler);
vTaskDelay(5000 / portTICK_PERIOD_MS);
void receiver(void * params)
while (true)
// 第一个参数和当时状态有关,第二个参数是一个timer,portMAX_DELAY的意思是,除非收到xTaskNotifyGive,不然就会一直阻塞在这里
ulTaskNotifyTake(pdFALSE, portMAX_DELAY);
printf("received notification");
void app_main(void)
xTaskCreate(&receiver, "sender", 2048, NULL, 2, &receiverHandler);
xTaskCreate(&sender, "receiver", 2048, NULL, 2, NULL);
结果:每5秒打印一次received notification
