1. 搭建 cloud flare tunnel
官方教程在此。
2. 测试下行
测试下行即测试下载速度,假设有两个server: server1 server2,其中 server1:[port] 上搭了cf tunnel 做 frp,用 server2 来下载 server1 上的文件。
- server1 创建一个 1G 的测试文件
# dd is the command from Linux that i use. To create 1 GB file go with
dd if=/dev/urandom of=testfile bs=1024 count=1024000
# to create 100 MB try
# and for 10 MB use
- server1 起一个 http server
python -m http.server [port]
- 用 server2 来下载 server1 上的测试文件
wget http://url/filename
对于 1G 的测试文件,测试结果如下:
测试过程属于是越跑越快…刚开始下行不到 1MB/s,最后一点点升到 4MB/s 了。
3. 测试上行
测试上行也即上传文件,从 server2 传一个文件到 server1 上。
参考链接:Python SimpleHTTPServer to receive files - Stack Overflow
在 server1 上创建 python 文件:
#!/usr/env python3
import http.server
import socketserver
import io
import cgi
# Change this to serve on a different port
PORT = [port]
class CustomHTTPRequestHandler(http.server.SimpleHTTPRequestHandler):
def do_POST(self):
r, info = self.deal_post_data()
print(r, info, "by: ", self.client_address)
f = io.BytesIO()
if r:
f.write(b"Success\n")
else:
f.write(b"Failed\n")
length = f.tell()
f.seek(0)
self.send_response(200)
self.send_header("Content-type", "text/plain")
self.send_header("Content-Length", str(length))
self.end_headers()
if f:
self.copyfile(f, self.wfile)
f.close()
def deal_post_data(self):
ctype, pdict = cgi.parse_header(self.headers['Content-Type'])
pdict['boundary'] = bytes(pdict['boundary'], "utf-8")
pdict['CONTENT-LENGTH'] = int(self.headers['Content-Length'])
if ctype == 'multipart/form-data':
form = cgi.FieldStorage( fp=self.rfile, headers=self.headers, environ={'REQUEST_METHOD':'POST', 'CONTENT_TYPE':self.headers['Content-Type'], })
print (type(form))
try:
if isinstance(form["file"], list):
for record in form["file"]:
open("./%s"%record.filename, "wb").write(record.file.read())
else:
open("./%s"%form["file"].filename, "wb").write(form["file"].file.read())
except IOError:
return (False, "Can't create file to write, do you have permission to write?")
return (True, "Files uploaded")
Handler = CustomHTTPRequestHandler
with socketserver.TCPServer(("", PORT), Handler) as httpd:
print("serving at port", PORT)
httpd.serve_forever()
然后运行这个 python 文件。
另外在 server2 上,用上面的方法也创建一个测试文件,然后运行 curl -F 'file=@<FILENAME>' http://<IP> -w 'time_connect %{time_connect}\ntime_starttransfer %{time_starttransfer}\ntime_total %{time_total}\n'
对于 20M 的测试文件,测试结果如下:
其他注意事项
- 为什么 url 后面不用接端口号?
- 因为 cf tunnel 默认就有端口号,不需要额外添加。
