vllm model 接入 claude code 指北
Step 1. vllm 启动 glm
vllm serve ./GLM-4.7 \
    --tensor-parallel-size 8 \
    --tool-call-parser glm47 \
    --reasoning-parser glm45 \
    --enable-auto-tool-choice \
    --served-model-name glm-47 \
    --api-key token-abc123 \
    --host 0.0.0.0 \
    --port 8001
注意这个 --tool-call-parser 和 --reasoning-parser 一定要按照官方的来,我是参考的 zai-org/GLM-4.7 · Hugging Face 这个的写法
Step 2. 用 claude-code-router 把 vllm 的 openai-compatible 格式转换为 anthropic 格式
参考 GitHub - musistudio/claude-code-router: Use Claude Code as the foundation for coding infrastructure, allowing you to decide how to interact with the model while enjoying updates from Anthropic.
编写 ~/.claude-code-router/config.json 文件:
  "LOG": true,
  "LOG_LEVEL": "debug",
  "Providers": [
      "name": "myvllm",
      "api_base_url": "https://xxx:port/v1/chat/completions",
      "api_key": "token-abc123",
      "models": ["glm-47"],
      "transformer": {
        "use": ["openai"]
  "Router": {
    "default": "myvllm,glm-47"
Step 3. 启动 ccr code
运行 ccr code 用 ccr 来启动 claude code:
root@xxx-cpu-xxx:/path # ccr code
Service not running, starting service...
╭─── Claude Code v2.1.25 ────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────────╮
│                                                    │ Tips for getting started        │
│              Welcome back IcyFeather!              │ Run /init to create a CLAUDE.md file with instructions for Claude        │
│                                                    │ Recent activity        │
│                       ▐▛███▜▌                      │ No recent activity        │
│       glm-47 · API Usage Billing ·                 │        │
│       xxx@gmail.com's Organization      │        │
│         /path        │        │
  /model to try Opus 4.5
❯ hi
● Hello! How can I help you with your software engineering tasks today?
❯ list cur dir files
● Read 1 file (ctrl+o to expand)
  │ Type │                 Name                 │
  │ file │ CC-Switch-v3.10.2-Linux.deb (8.7 MB) │
  │ dir  │ LLaVA-Med                            │
  │ dir  │ agent                                │
  │ dir  │ aiscientist                          │
  │ dir  │ benchmark                            │
  │ dir  │ dataset                              │
  │ dir  │ download_model                       │
  │ dir  │ litellm                              │
  │ dir  │ llm_api_test                         │
  │ dir  │ med3dmodel                           │
  │ dir  │ medireason                           │
  │ dir  │ model_infer                          │
  │ dir  │ tmp                                  │
  │ dir  │ upload_model                         │
如果要配置多个模型
比如我又配置了一个 Minimax-M2.1,编辑 ~/.claude-code-router/config.json:
  "LOG": true,
  "Providers": [
      "name": "glm",
      "api_base_url": "https://xxx/v1/chat/completions",
      "transformer": {
        "use": ["openai"]
      "name": "mm",
      "models": ["minimax-m21"],
      "transformer": {
        "use": ["openai"]
  "Router": {
    "default": "glm,glm-47",
    "think": "mm,minimax-m21"
配置完了之后 ccr restart 重新 load 一下配置然后重新 ccr code 即可启动,用 /model minimax,minimax-m21 即可切换模型:
root@xxx:/path# ccr code
 ▐▛███▜▌   Claude Code v2.1.25
▝▜█████▛▘  mm,minimax-m21 · API Usage Billing
  ▘▘ ▝▝    /path
❯ /model mm,minimax-m21
  ⎿  Set model to mm,minimax-m21
  ? for shortcuts
